TUNNEL DESIGN
Hira Malik
I AM TIRED OF SEARCHING WEB FOR TUNNEL DESIGN MATERIAL. GOT ONE EXCEL SHEET WITH SHORT CALCULATION AND NO IDEA HOW THEY DID IT. PLEASE REFER ME TO ANY TUNNEL DESIGN SOFTWARE OR MANUAL EXAMPLES SO THAT I MAY BE ABLE TO UNDERSTAND TUNNEL DESIGN IN DEPTH.
Hira,
I found the following:
Technical Manual for Design and Construction of Road Tunnels — Civil Elements
Guidelines for the Design of Tunnels - ITA Working Group.pdf
Structure and Construction Examples of Tunnel Reinforcement Method Using Thin Steel Panels.pdf
http://structuraldesignbs.blogspot.ca/2015/11/tunnel-design.html
Link to Source: Google Search
What I would suggest is that find two or three good books on tunnel design and ask your employer to buy them and use them as books have a lot of solved examples.
20 hours ago, UmarMakhzumi said:
Hira,
wow thats great. thanx a ton !!!
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
