two way beams and slab design using CSI SAFE
Muhanad
*Dear Respect Engineers,
I made a one story structure 9 x 9 m with cantliver slab on beams but the negative moment doesn't show in the interior beam in the way we used to find it in the regular designs and regarding the slab strips there is no much negative moment plus: shouldn't the deflection happens in the places (center) of slab surrounded by beams?
I have another sample that I made it for a building executed along time ago 9*20m and there was a much negative moment over all the exterior and interior beams but when I model it in SAFE there was on much negative moment over the all the beams .
and reflectively the reinforcement was much less in SAFE results than the one we executed.
Please any one have an idea.?
8x10 slab.Y~1
Looking at the beam layout in Figure titled Cantilever-1, I can judge that you have one-way slab panels. Check the ratio of long to the short side of your slab panels. So, you don't need to take strip moments from ETABS/SAFE.
Yes, end moments of your beams are not correct. Check the connectivity of nodes in your model.
