Which FEA / CAD / CAE SWs are most used in Pakistan?
Martin Blazek
Hello,
I am curious which of those are most used: SAP 2000, STAAD.Pro, Robot Structural Analysis, ETABS, SCIA Engineer, RFEM/RSTAB, MIDAS Civil + Gen, Tekla Structures, Advance Steel, Revit, Advance Design, AxisVM, ConSteel? (for steel structures).
Also I would be interested to know about reliable software dealers of those products.
Thanks for help.
In my opinion, ETABS and Safe are the most commonly used softwares for buildings and foundation analysis  followed by Staad. In general, a very few companies use licensed softwares. Like 99% structural  softwares being used are cracked and pirated.
For FEA SAP200 is used. For CAD nearly all Pakistan uses AutoCAD. It is easy to get cracked softwares then to find a licensed dealer in Pakistan.
Edited by Ayesha
Thank you for the answer. It is a big help to me. However, how is it with big official or multinational companies?
Do they also use unofficial software or are there some companies in Pakistan where ETABS, SAP2000 can be purchased?
On their web pages there isn't much about resellers/distributors.
2 hours ago, Martin Blazek said:
Hi, thanks for the confirmation.
Could you please get in touch with me via idea.statica.reseller@gmail.com?
No offence but your email looks like scam. Do you have a website?
Hi again,
Yes, we do have a web - www.ideastatica.com.
I am just interested in the structural engineering sw dealers in your country.
Just curious about what is being sold (on corporate level) and if there are any reliable established resellers.
Thanks beforehand
Edited by Martin Blazek
  • 4 weeks later...
Hi again, I was waiting for some time.
Can I ask kindly for a help to locate in Pakistan established companies involved in distribution of structural design software?
Even Autodesk does not have official resellers in your country: https://www.autodesk.com/partners/locate-a-reseller
Same with Bentley, C.S.i, etc.
Thank you beforehand
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
