Sap Import/export Problem
WR1
SAP Import Export Problem
SAP Import and Export $2k File
Today I faced a very strange problem in CSI SAP. Have you ever faced such a problem in your structural analysis tools? Same model file was used which yielded different results under following 2 scenarios:-
1) 1-The original file was run in SAP.
2) 2- Then this file was exported in text format and imported again.
Value of TIME PERIOD of both the models were different and we found out that there is about 300kN difference in Self Weight of elements. I examined both the text files in MS WORD Compare Document feature and found out that a beam having depth of 700mm has been added in new model (model based on importing the text file) on various locations other than the original one. While in the model when I showed selection only for this 700deep concrete beam I found it to be everywhere in the model. I will explain the solution of the problem in next lines. Actually the original model exported from ETABS to SAP so I cannot confirm whether all this discussion holds good too for the models originally created in SAP or not?
Actually there were some NULL lines (created originally in ETABS) in the model. When you export the model as a text file and import it back it does not recognize the NULL lines but rather it applies those elements the first available section which in my case was 700mm deep concrete beam. So that’s why I got 300kN more self weight in the model due to these beams.
So next time you export your model to SAP and send its text file for review to another person or firm, be informed that it will give them wrong results. So always send them SDB file.
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
