Design Guide - PEB Structures
Muqtadir
19 hours ago, Muqtadir said:
was hoping someone might be an expert at this in this forum, could give me a heads-up to the practically applicable design guides in the industry.
PEB structures are a special type of steel structures. These are less common in our country, as compared to RC structures . Accordingly, very few firms or structural engineers design these structures. Some locally known such firms include Zamil Steel, PEB Steel, Mammut, Izhar Steel etc. Larger firms have their own design manuals (and in some cases, their own special  software as well), which you may search on the internet.
UmarMakhzumi  has pointed out to the proper source & authority dealing with this type of structures.
Analysis & design of PEB structures is similar to normal steel structures. However, MBMA Manual provides better design aids (based mainly on ASCE 7), especially with reference to application of wind loads to this type of steel structures. In addition, it has several detailed wind analysis examples dealing with Enclosed, Partially Enclosed & Open type steel buildings.
This manual will be a very useful source for understanding the design of steel & PEB structures covered in MBMA , in case you already have a good command on the use of AISC Manual of Steel Construction.
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
