SAP negative masssource
Hafsa Azmat
Hi there
I am analysing a building in which i have assigned some negative point loads cause of pull from my equipment loads in live case, when i m running analysis its is giving warning for negative values in mass source ( i have added that case in mass source as this case includes both gravity and pull forces)
Is there any way not to delete those pulling loads and remove the warning in my mass source
So lets locate the negative mass source values. The image that you have attached in the post above says that:
  Quote
See Table "Assembled Joint Masses" to locate negative mass value.
Share that table and lets probe it. So far it looks like that you might have applied equipment loads to a slab and this error that you are getting is because of meshing. I am not sure if that is the case, this is my guess. Anyway, please share the table and we can pin point the problem area.
Also, for general information, this is what ETABS does to convert load patterns into Mass Source.
  Quote
If the option Specified Load Patterns is selected, the loads acting at every joint are computed from the scaled combination of the load patterns. Only the component acting in the global Z direction at each joint is of interest. This result is then divided by the gravitational constant and applied as equal mass to the three translational degrees of freedom in the joint. Downward loads generate positive mass and upward loads generate negative mass.
Source: http://docs.csiamerica.com/help-files/sap/Menus/Define/Mass_Source.htm
and also this:
  Quote
It is possible to assign negative mass to a joint as long as the total mass tributary to the joint remains positive (or zero). If negative mass is assigned to a joint, do it with great care. If SAP2000 detects negative mass at a joint during the analysis, SAP2000 will set the joint to zero with a warning.
Source: http://docs.csiamerica.com/help-files/sap/Menus/Assign/Joint/Joint_Masses.htm
Hi Sir,
I am using Sap 18 for analysis. I had a look at assembled joint masses, where I see and located the joints showing -ve masses, but its program calculated and I don't want to alter that.
I have not applied any loads to Slab mesh point.
What I have done is, I have assigned my equipment pulling load in new Load pattern “L.L-Pull” and didn't added that Load Pattern in my Mass Source. That way I am not having warning for "-ve Mass source". And added that new Load Pattern in my Old Case “L.L” to counter it in member Design.
