Which Etabs Version is the best?
MIK
Deal All
Please suggest according to your experience that which Etabs Version is the Best one in the latest Version starting from Version 9 to version 16
Generally speaking, newer versions come loaded with new features so if you aren't using the latest and greatest, you are missing out on a number of newly added options. I generally recommend the version for which you have read the Software Manual. It is very important to know the limitations of your ETABS/ Structural Engineering Software version. Nothing else matters as much as that.
Thanks Dear Umar Makhzumi for your suggestion. i am using ETABS V 9 but now i want to shift to advanced versions so i need help from the experienced persons already using the advanced version that which one should i use. i have left with two option version 15 and version 16..which one should i use?
But some times there are bugs in the very latest versions.
I would recommend not to use the very latest version. I usually use v13 for designing but also use the latest version for checking and application of new features of new versions.
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
