Petrol tank foundation
Mukhallad Murad
On 11/20/2018 at 11:47 AM, Mukhallad Murad said:
I have petrol tank 30 ton  rest on ground its size 10x 5 m . I wnat to design raft foundation but the tank it rise by 0.5 m from top of foundation.Is foundation will design for uniformally load or concetrated load depends on supports (0.5 m) and how the load will be on supports
You can provide a big pedestal that can support the tank and have a raft below. If the tank is supported on steel skirt (circular steel vertical ring) this is mostly the case for vessels, then you should apply the load as line load. If that is not the case and the tank is a simple tank (flat bottom), then just provide cementitious non-shrink grout between your pedestal and underside of tank and apply the load as UDL on the pedestal.
Let me know if you have any additional questions as work in Petrochemical Industry and this is very common.
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
