Mehran Rafiq
This is a very loaded topic, it needs a lot of study. These are some of the documents: ASCE-41-13; FEMA P-58_Volume1_508 Seismic Performance assessment of buildings; PEER-ATC-72-1_Modelling and acceptance criteria for the seismic design of tall buildings; NIST GCR 10-917-5 Nonlinear Structural analysis for seismic design; NISTIR 7766 Evaluation of contemporary design of reinforced concrete.
I am not aware of any tutorials on this one.
Some workshops are going on throughout Pakistan by Naveed Anwar from AIT namely "Performance Based Design of Tall Structures"
They provide Hands-on training. Recently in April 2018 workshop was conducted in NEDUET. I think it recently occurred in NUST as well in October 2018.
I would recommend you to attend this workshop whenever it is going to held in future for detailed information
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
