FEA Research Paper
Shahzad Khan
Aoa, hello guys, Idk how to start problem here but let's just make it straight. I'm studying FEA in my Master studies and the teacher has assigned me task to select any research paper based on finite element analysis, provide summary of research paper and regenerate the results using software. I selected a research paper, which was based on comparison of results of strap footing settlement using SAP, ETAB and manual calculations. The comparison was for results. I reproduced the same results in software and submitted to my course instructor. He rejected the results and told me to select any research paper which actually shows what happens inside the structure and regenerate the results. This project carries 15% weight of subject marks. I'm unable to find research paper which actually shows the required results. If you think, it's possible, please whatsapp me at --- ASAP.Put your reviews here too. JazakAllah.
Edited by UmarMakhzumi
Phone Number Deleted.
Wa alaikum us salam,
SAP and ETABs do not work fully on FEA.
You should use paper showing results regarding stress distribution, strains, etc. Search for papers using softwares like ANSYS, LS DYNA, DIANA, ABAQUS, ATENA, etc. Right now, for initial stage, I would recommend you to search for FEA of simple beam.
Let me know, if you require any further help.
You can use the following paper. it have manual verification as well. But I hope you should try doing it yourself and then check the manual verification. because learning is more important
Crack Identification in Reinforced Concrete Beams Using ANSYS Software
L. Dahmani,a A. Khennane,b and S. Kacia
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
