Develop Stress Strain Curve (Mander) using SAP2000
Fatima Khalid
Asalamualaikum,
I want to verify the Mander nonlinear concrete model using SAP2000. I have taken default material properties of concrete 4000 psi. Then I have made a 6x6x6 inches cube and the technique was to apply load and note down the deformations. Then I have converted Load into stress and deformation into strain. Unfortunately I am getting Linear stress strain graph.
Any idea how can I develop stress strain graph by representing concrete compression cube test.
If you set loading type as nonlinear and set the load application control as displacement, then check if you are able to get convergence in your model. I tried to model material nonlinearity of RCC in a different context, I couldn't get the desired result in SAP 2000.
@BAZ I was unable to get the desired results on SAP2000 using solid element. So I have found out that material non-linearity in solid elements can be considered only by using Link elements. In my criteria, I can not place link elements.
Therefore, the concluded result is that I can not simulate compressive strength test using SAP2000
