Under water concrete with ground granulated blast furnace slag (GGBS)?
Mubeen Abid
Hi,
I have one tower in Dubai with 2B+G+4Podiums+37 floors, for which I have raft on pile foundation, The piles are bored cast insitu piles, the concrete grade recommended for piles is C60 with waterproofing admixture. Water table for this site is 6m below natural ground level.
During the drilling process for piles we encountered water in all pile trenches and the concrete has to be casted in the water as we cannot drain the water, but contractor does not want to use water proofing admixture as ground granulated blast furnace slag (GGBS) is used in concrete mix. my query is
1) Is GGBS enough to act as water proofing agent???
2) Can we cast concrete with GGBS under water without loss to durability???
Muneeb,
Before I reply the question, I just want to confirm that by water proofing did you mean water reducing? if yes, then GGBS can reduce the amount of water required to achieve given concrete strength. Anyway, if you didn't mean that then please see the response below.
Generally these questions should be refereed to the company providing the concrete mix design.
Ask the concrete mix design company (or ask your contractor to get this answer for you) if the mix design being provided have equivalent water proofing property) as that provided by the admixture. You can provide them the admixture data sheet so they can do they comparison and let you know.
I am not aware of any property of concrete that directly measures waterproofness. However, you might be able to establish co-relation if durability properties achieved are same with GGBS as with admixture.
