Torsion modifier in sap2000/etabs and short columns
PES
I modeled the house shown in the attached picture in sap2000. All columns are 30x30cm, the yellow and red beams are 30x30 cm and the orange beams are 20x25cm. When I analyzed the structure, some beams failed in torsion and shear so I reduced the torsion modifier of all beams to 0.01. With a torsion modifier of 0.01, all beams passed the analysis but I am worried about the yellow beams because the beams in the F and H axis are being directly supported on those yellow beams so I am not sure if it is appropriate to reduce the torsion modifier to 0.01 in this case. If I increase the torsion modifier to 0.2, the yellow beams will fail between the C and H axis. What should I do? Should I keep the torsion modifier to 0.01 or increase it? If so, by how much should I increase it?. As a general question, should I decrease the torsion modifier of all beams or only of the ones that fail?
That house also has three short columns in the 2-axis with an effective length of 0.38 cm. I would appreciate any recommendations or things I should keep in mind or consider when modelling and detailing those short columns.
Any general recommendations about the model would also be appreciated.
Thanks in advance
Edited by PES
Your questions are good and there has been some discussions on the forum about these. Generally for beams subjected to compatibility torsion, it is safe to reduce torsion in them as there is more than one load path available. What happens is that when you don't provide torsion reinforcement for your beam (or in other words if you have under-designed for torsion), the beam would crack (making any torsion stiffness zero like what you assumed in ETABS) and re-distribute the load. This generally results in more reinforcement in beams center. Even for the case when one beam is being supported on another, keeping torsion modifier to zero would result in more deflection of the beam that is supported and little cracking at the support end but nothing to worry about. . One important thing to note here is that for flat slabs, where you have perimeter beams, reducing beam torsional stiffness would lead to in-effective design. You can think about it and hopefully will understand why.To understand, when you can reduce torsion stiffness to zero, see the following topic and check additional links provided in the discussion.
If this house is in seismic region, short columns would attract major chunk of seismic load as they are more stiffer and stiffness attracts loads. Check out the following post as it contains an attachment on why short columns are more dangerous and what precautions shall be taken.
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
