Column Design And Analysis Moments don't match
SMAQ
Need Urgent help regarding Column Design Issue. I am working on G+4 Building Model where I am struck in the output of one particular column, whose design and analysis Moments are not MAtching. I checked my model several times but could not find the bug.
The Analysis Moment M33 = 1.7 kNm and design moment M33 = 81.6 kNm . Also for this loading the the percentage of Steel seems to be huge. I am attaching the pics and, also the model for your reference. I will be thankful if the members please help me sort this issue.
SMAQ
QMD-R-5-woeq.EDBFetching info...
Hello All,
I was checking my model again and I found out that, when I am dividing the main beam RB-3  connecting this column to connect the secondary beam RB-2, I am getting this result and, when I am keeping the main beam RB-3 continuous than results are okay.
Can anyone please put some light on this. Why this is happening.
  On 3/27/2019 at 1:44 PM, SMAQ said:
Hello All,
Because that might be causing your main beam to act as a cantilever beam and transfer a bigger moment to column. See deflected shape and it will confirm the hypothesis.
