Estimation of Block Masonry
Engr. Salman
Assalam O Alikom Engineers!
I hope you will be safe and sound. I am facing difficulties in estimation of Block Masonry as I don't know the constants of Estimation for such Masonry. There are several reasons e.g
In the calculation of brick masonry in Pakistan, we consider 30 percent of mortar is required, so How much in Block Masonry, the second reason, There is no constant size in Pakistan, so If size is changed what will be its effects on the usage of mortar? Moreover, How much blocks are required in 1 cubic foot? such as in brick masonry 13.5 bricks are required.
These are all good questions. Since there is no standardization in Pakistan, the best thing to do would be to determine it on a case to case basis. For example, if you need to provide an estimate, go checkout a local construction site where block masonry is being done, and measure quantities for small sample. Then use the ratios for your project and state listing your assumptions. I am not aware of how this is addressed in Pakistan. If someone has estimation experience relevant to the posted question, please feel free to comment.
Cheers!
