Tie Beams between Pile Caps
Muhammad Munaf
Respected all, I am working on project which has foundation consist of Pile Caps, Tie beam and tie slab. The problem which I felt is that when I see reinforcement of tie beam it shows me too much reinforcement like 30-#8 in top and around 20-#8 with beam size 18"X72"(Depth as per Pile Cap Thickness), all the reinforcement is showing in SAFE. But when I resized the tie beam size to 12"X24" it shows very lesser reinforcement. Now the question arises in my mind is that what to do with size of tie beam?
Can I reduce the size of tie beam if yes then can some one provide code backing or authentic background?
or if not possible then I can placed the same reinforcement as provided by SAFE.
Based on the thickness of tie beam, between two pile caps, it would react differently to externally applied loads. For cases where your tie-beam is deep, it would provide significant restraint to any movement at pile caps end (it will act as a moment and shear restraint), and where it is not, it won't  (only axial restraint) so reinforcement would be different for different depths as stiffness is different.
You can reduce the size of tie-beam, and check the response. A reduced depth tie beam would mean more reinforcement in pile cap and vice versa. There are trade offs in pile cap or tie-beam reinforcement depending upon the thickness of the beam and you will have to pick the one that suits you.
