RAFT Design (Variable Thickness) SAFE 2016
Nabeel Sheikh
Hi,
First of all kudos to the administrators for taking the initiative of providing this platform. I am new here and i hope to contribute and gain maximum from this portal.
I am designing a B+G+2 RCC Building with a foot print of 30x40(ft). Owing to the architectural requirements columns have been provided along the edges only giving a span of 30ft c/c in x dir while 14ft in y direction. The Allowable bearing capacity is 0.8 tsf for raft. There is a basement retaining wall 8ft high while the story height is 12ft. So, the RCC wall is only for soil retention. Initially, i tried to provide isolated footings but the bearing pressure was well above the allowable. So, i resorted to raft foundation. I didn't model the RCC wall in SAFE to check the punching shear; which eventually lead to a  raft thickness requirement of 27 inches. My questions are:
1) Is there a way to optimize the raft by NOT providing the 27" thickness all over the area?  Like, the area in vicinity of columns can have 27" thick while the remaining raft can have lesser thickness? If there is a way, please provide some details of doing it in SAFE. Considering the size of this project, it may not save much but i need to learn this technique of  modeling the raft with variable thickness.
2) There is always a failure of bearing pressure when columns are located along the edges of raft. Yet it's quite a common practice to provide columns along the edges of raft. How such rafts are designed? I am facing the same problem here.
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
