Moment Capacity of retrofitted section
Fatima Khalid
Asalamualaikum
I use manual method or Response2000 to find yield moment capacity of RC sections. In case, if I have a section 12”x12” having 4-#6 bars... i can easily calculate the capacity.. but if this section is retrofitted with steel L4”x4”x3/8” member at all four corners then how can I calculate the moment capacity? (see attached picture, the bold corners showing L shape steel members)
Thank you
One way will be to use sections designer in CSi softwares (Sap 2000, ETABS, Csi Col). Model four angles with re-bars by locating them at the centroid of of angles. You will have to define material for that reinforcement. This will be in addition to the existing reinforcement in  the cross-section
You can easily calculate the moment-capacity provided by four angles by manual calculation keeping in mind the crushing strength of concrete, and add it to existing capacity.
Fatima,
What has been stated above by Baz is very useful and you can use it for composite sections of any given configuration.  Generally speaking, strength contributions by steel angles are very low and wouldn't add much to a concrete column section. I have used angles at corner of concrete section to allow welding of lighter items (like small pipes or cable trays) or to protect the corner from deterioration. I would suggest to ignore angles and don't rely on them.
Now lets say you still want to consider the angles, for that case follow what Baz has said. So you can model a composite section or manually calculate the moment of inertia of combined section. By doing that, you can run analysis model and get your moments in the composite member due to the applied loads. Additional checks to do would be to make sure the bolts connecting the angles to the concrete don't fail before your angle attains yield strength. You can calculate the force in the bolts by using the Shear flow formula VQ/I. You will need to check different sections along the length as moment is changing constantly along the length. I hope this helps.
Edited by UmarMakhzumi
Fatima!
To calculate the capacity of the concrete member retrofitted with angles on four corners, could be done in the same way we calculate the capacity of concrete member reinforced with steel bars, if you are doing manually in computer we do not have such an option.
we can not consider it as composite member, since the all steel members (angles) can not have a single moment inertia which is to resist the bending
