Moment Capacity of retrofitted section
Fatima Khalid
Asalamualaikum
I use manual method or Response2000 to find yield moment capacity of RC sections. In case, if I have a section 12”x12” having 4-#6 bars... i can easily calculate the capacity.. but if this section is retrofitted with steel L4”x4”x3/8” member at all four corners then how can I calculate the moment capacity? (see attached picture, the bold corners showing L shape steel members)
Thank you
One way will be to use sections designer in CSi softwares (Sap 2000, ETABS, Csi Col). Model four angles with re-bars by locating them at the centroid of of angles. You will have to define material for that reinforcement. This will be in addition to the existing reinforcement in  the cross-section
You can easily calculate the moment-capacity provided by four angles by manual calculation keeping in mind the crushing strength of concrete, and add it to existing capacity.
Fatima,
What has been stated above by Baz is very useful and you can use it for composite sections of any given configuration.  Generally speaking, strength contributions by steel angles are very low and wouldn't add much to a concrete column section. I have used angles at corner of concrete section to allow welding of lighter items (like small pipes or cable trays) or to protect the corner from deterioration. I would suggest to ignore angles and don't rely on them.
Now lets say you still want to consider the angles, for that case follow what Baz has said. So you can model a composite section or manually calculate the moment of inertia of combined section. By doing that, you can run analysis model and get your moments in the composite member due to the applied loads. Additional checks to do would be to make sure the bolts connecting the angles to the concrete don't fail before your angle attains yield strength. You can calculate the force in the bolts by using the Shear flow formula VQ/I. You will need to check different sections along the length as moment is changing constantly along the length. I hope this helps.
Edited by UmarMakhzumi
Fatima!
To calculate the capacity of the concrete member retrofitted with angles on four corners, could be done in the same way we calculate the capacity of concrete member reinforced with steel bars, if you are doing manually in computer we do not have such an option.
we can not consider it as composite member, since the all steel members (angles) can not have a single moment inertia which is to resist the bending
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
