Structural Design Codes in Pakistan?
Simple Structures
Can someone help me determine the "standard design codes" to be used in Pakistan for designing building structures;
The Pakistan Building Code is a 'cut & paste' document with little practical guidance - hence superfluous I would say.
Which codes do you use for 'structural design of elements’?
1. Wind Loading -?
2.  Concrete design -?
3. Steelwork Design -?
4. Masonry design -?
5. Timber design -?
6. Geotechnical design -?
7. Earthquake design?
& so on etc etc.
There is the American Codes (ASCE, ACI, AISC, ADM) and European Codes (Eurocodes, EN, EC0, EC1, EC2 etc) for each of the above and more;
Should Pakistan be adopting Eurocodes with the Turkey's Nationally Determined Parameters?
Who is the custodian of the design codes ruling in Pakistan? PEC (another of the country's quango that is more interested in ticks box exercise, or am I wrong is that assumption) or is there another body that one can look to for guidance?
Any feedback on the matter from learned Members would be most welcome.
Edited by Simple Structures
This is a great question. I will share what I have been using:
1. Wind Loading -?
Mostly ignored it while working in Pakistan as seismic governed. For cases where had to consider UBC 97 was used. At some project I also used IBC as I had a supplement that provided the environmental parameters for wind, seismic and snow.
ACI 318-02
AISC 360
Zilch
5. Timber design -?
Never did.
Consultant in all the cases.
ACI 318-2, UBC 97 mix
& so on etc etc.
In addition to above, I once got the chance to use Eurocode for a British Embassy Project but that was exception to the rule.
Pakistan should work on improving it's own code. We would be better off improving on American codes as people are more familiar with them.
I think you can get contact information on this if you have a copy of Pakistan Building Code. please see the following link for more details:
https://www.pec.org.pk/building_code_pakistan.aspx
It would be great to see what others have been using in Pakistan.
1. Wind Loading -?
5. Timber design -?
& so on etc etc.
All the design codes are well-mentioned by Umar. As far as timber design is concerned you can refer to NDS (national design supplement) and AWC ( American wood council) documents. The wood engineering properties are based on species found in US and cannot be used for Pakistan timber industry. The potential of timber in Pakistan still needs to be investigated.
