Inverted Beam Behaviour
Yannick Taloe
Dear Yannick,
Both the beams behave similarly. However, while detailing, you detail the inverted beam as an upside down normal T beam. That means, now your bottom tension rebar(in span) can be distributed within the whole flange width. At supports, the flange part of beam will be in compression. Hope this helps.
I'll add, Both the beams behave similarly in "flexure", for a simply supported beam. For a fixed end beam, special detailing need to be provided between beam and columns to transfer the end moments.
For "Shear", however, the behaviour is completely different. Because the "compression struts" carries tension and does not remain in compression, unlike downstand beams. So the shear resistance provided by concrete compression struts becomes close to zero. IMO it's safer to design upstand beams considering Vc=0.
On 1/24/2020 at 2:00 PM, Yannick Taloe said:
What is the difference between a rc inverted beam and a rc normal beam in terms of behaviour and reinforcement detailing ?
In addition, The links (stirrups) will need to be designed (sized) for both their normal "shear function" and also for "vertical tension" - on the links/stirrups from the slab "hanging"  below them.
Design links/stirrups as bars (also) in tension - reinforcement diameter may well increase in size.
