Bridge Design Guideline
Asif Mostafa
AA.
    Depending upon whether you want to follow American or European codes, following references might be helpful in learning the design of bridges:
1. Based on American codes
    a. Design of Highway Bridges_An LRFD Approach by Barker and Puckett
    b. AASHTO LRFD Bridge Design Specifications
    c. AASHTO Guide Specifications for LRFD Seismic Bridge Design
    d. Design of Modern Steel Railway Bridges by Unsworth
    e. AREMA Manual for Railway Engineering (MRE)
2. Based on European codes (Eurocode)
    a. Designers Guide to Eurocode 1_Actions on Bridges
    b. Designer's Guide to EN 1992 Eurocode 2 Design of Concrete Structures Part-2 Concrete Bridges
    c. Designers' Guide to Eurocode 8 - Design of Bridges for Earthquake Resistance EN 1998-2
    d. Bridge Design to Eurocodes Worked examples (European Commission Joint Research Centre)
Edited by EngrUzair
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
