Raft retrofitting
abbaskhan2294
Dear all I want to discuss an issue recently encountered at site. Designer had given details of raft with #6 @ 6" o.c reinforcement BW in top and bottom meshes but contractor instead provided#4 @ 7" o.c. the raft and 1st story columns have been casted. On doing its capacity analysis the raft with provided reinforcement was not adequate to support to super structure. Now I'm thinking of doing retrofitting by providing an overlay of 9 to 12 inches. I wanted to know about shear keys/dowels for the connection between old and new slab. Can anyone provide any helping material for it? Thanks
  • 3 months later...
How come you know that after first storey columns are cast, where was"the engineer" sleeping somewhere
here no body can tell you the solution for that without any section/plan/building stories/spans/column size, ask your question with some snaps and proposal instead, that could be reviewed and something could be suggested.
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
