CSiBridge Multi Step Bridge Live Load Pattern Generation
Asif Mostafa
Can anyone help me with Multi Step Bridge Live Load Pattern Generation? I am having trouble in understanding how different parameters are set namely Start Distance, Start Time, Speed etc.
The problem is how do I identify the critical case such as how many vehicle will cross the bridge at the same time?
It will be helpful for you to see the example in the CSI help for the application of influence lines and traffic loading as it is a bit difficult to explain the procedure of loading pattern. Normally you have the UDL load for the bridge lane then your point axle loads followed by UDL at the end again. In most cases the speed limit is 10KM to 15kM just to see the maximum BMD and SFD.
For the number of vehicle crossing the bridge, you normally design for one vehicle with maximum load case going across the bridge. if you add more vehicles you worst case still will be with the first load case single vehicle.
See AASHTO or any other design code you are using you will see the application of maximum load case for single span. Just apply these loads no need to add so many vehicles on the bridge.
Thanks for the help. And should it be done by creating separate case for separate vehicle type such as HL 93K , HL 93M etc.?
Use influence line, moving load case for bridge live loads. Multi step case gives lesser value of maximum moments then moving load pattern in Csi Bridge. The number of vesicles and their lateral spacing depends upon the Code and type of loading you are applying.
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
