Strong column weak beam design in etabs
Aye Min Khaing
Beam column capacity ratio in etabs don't consider the rebar area in beam and column. I think it is not right concept. Fleaxural strength of column and beam may vary because of rebar area. It may need to manual check every joint as per rebar area that we design. Please discuss.
  • 2 months later...
Etabs considers the rebar area that it suggests in calculating the capacity ratio. How else do you think one can calculate the moment capacity without considering reinforcement in members.
Yes, you need to check it manually based on the reinforcement prescribed in structural drawings.
