Design code in Pakistan
Shahzad Khan
Is it legal to use a software for structure designing which design on other codes not on ACI with in Pakistan? i.e, Orion
I read the post (discussed in the group with detail) but i want to have a detail overview of pros and cons of other designing codes.
Edited by Tufail Mabood
European Consultants working in Pakistan are using British and European Codes & Specifications for world bank funded projects. Indeed, there are projects usin both ACI & Eurocodes at the same time!
India and Bangladesh and many other developing countries have their own structural codes - Pakistan does not sadly.... we like all things American it seems.
Most Pakistan Engineers are using outdated American Codes int heir - as buying revised codes every few years is expensive - also working to imperial units (feets, kips, inches etc), rather than metric units (KN, mm, m). It is unlawful in the countries where the codes originate from to use "out-of-date" Codes!
PEC - the authorising Engineering body - offers no advise, not does the Pakistan Housing Ministry!
Check out this page of pase.pk website, where I have tried to offer some information on codes:
pase.pk - codes
Best to check and agree first with your Client on acceptable Codes and Specification documents to use on the project!
pase.pk - codes
Thank you so much! I am going to joint for design consultants after my M.Sc Final Defense. I need to make sure which software suits and which code is best to study for designing. Thank you for your time.
There is also Pakistan Building Code which is basically based on UBC97. ACI code is used widely in Pakistan and consultants authorized by local building authorities like CDA use and do the vetting based on ACI. In case you use a different code, it might be a problem if the design lands with local authority. @Simple Structures is also right in pointing out and British and other International Consultants on international projects in Pakistan have a preference to use their code and in my opinion such use shall be taken as exception to rule, not the rule.
No code is going to help you, you brush your structural analysis skills and you can use any code.
After 30 years of designing buildings of many shapes and sizes, I still find interpretation of codes for specific detailed design issues require lot of engineering judgement and experience – and even from time to time clarification from those who have sat on committee that written codes on a regular basis! These findings are updated on subsequent revision of the code.
Many 3-D software programmes have made performing structural analysis easier - provided you fully understand the fundamentals of structural engineering, member stiffness, joint releases, torsional restraints, buckling, shear interfaces etc.
Believe you me they are both equally as important; you cannot design with one alone, without having a good knowledge of the other.
Thank you so much!
