Dual frame design in etabs
Aye Min Khaing
Dual frame deaign in etabs.
I make a 3d model, shear wall and SMRF dual frame with R=7. I draw shear wall with boundary element (actually it is column same thickness with shear wall). I convert EQX and EQY to SPECX and SPECY for response spectrumn analysis (I adjuat static base shear with dynamic base shear with scale factor). And then, I make a another new model with save as option of old model. In new modal, I delete shear walls without boundary element ( It is small column) and reduce SPECX and SPECY with scale factor to get base shear 25% of total base shear of old madel. And i will design moment frame from control of both model. Is it right?
Thank you.
Thank you.
Design shear wall from the old model without scale factor and moment frame from the same model if columns are taking more than 25% of the total design base shear. Incase columns are taking less than 25% of the design base shear then modify the model with an upgraded scale factor so that your moment frame is designed for atleast 25% of the design base shear. I hope it helps.  Goodluck!
