SAP2000 Problem with building deformation from seismic load
vastejzma
Hi everyone,
Does anyone know how to solve the following problem: I have modeled a 9 story building with 2 cores (4 shear walls in X and Y directions). Columns should transfer only vertical loads, and shear walls horizontal loads. When I run the analysis for earthquake and wind loads, deformation in Y direction is as expected (shear walls are bending like cantilever beams and I have expexted moment in section cuts), but for some reason in X direction deformation looks like its primarily shear deformation with very little bending. Moments are 5 times lower than in Y direction. I am trying to solve this problem for days, so I would appriciate every possible help. I will attach the model as well as screenshots.
MODEL KOJI RADI.sdb
Yes, there is something wrong with the model. I tried to check your model, but it is not responding.
IN X-direction, building is exhibiting a rigid body motion above first level. You need to check your inputs related to seismic forces as well as restraints.
Could it be possible that the load in x-direction has been applied at the first level only?
Thank you for your response. I've assigned body constraints in the points where some beams connect to the "middle" of the shear wall. If I don't do that, model behaves like beams are not connected to the wall, period of oscillation is above 100s, and modes of modal analysis basically consists of displacements of those beams.
However, when I remove body constraints, deformation due to the seismic load looks normal and moment in the shear wall increases.
So basically now I am trying to set shear wall as a support for beams without using constraints. Any advice?
Thanks in advance.
I am not sure what you mean by "middle of shear wall". Shouldn't shear wall serve as the support for beams anyways? Can't comment because I am not able to understand reason for your modelling-approach.
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
