How to model a swimming pool at top roof of a building
fahmi
Yes, and check the case for building period with or without the mass on top that is for 2 cases.
1) Swimming pool is full.
2) Swimming pool is empty.
Both will give you different period. Swimming pool is nothing but just load. So treat it like one. Also, make sure you design the bottom slab of swimming pool for crack control and water tightness. You can search this forum as this topic has been discussed to death here.
