Modelling A shell Element with Compression only properties (i.e Brick wall on a slab)
ash
Hi Umar
Thanks for replying
I am trying to model a pure masonry wall behavior  in 3 story building, the wall will only transfer the gravity loads but wont take any axial tension.
Critical part comes when we have a beam/slab  which is hogging due to adjacent span or any uplift, wall elements takes tension from it and try to hold down the beam/slab. and change the actual behavior of the structure.
I just want to transfer the gravity loads through the modeled walls, but not the tension (as there will be no tension in brick wall elements due to hogging), but ofcourse in sagging case my walls should act as compression element and shall transfer the loads from above as per their material properties.
Trying to simulate a house with brick walls over/under slabs, beams to check the stresses and load concentration in my structure.
Thx in advance
This shouldn’t happen as beam is not connected to wall and only resting on wall in real world case - therefore your modelling should represent it. There was also another question on the forum on modelling CRP and I think the same reply would fit here. Contact, gap etc are better modelled in FEM software. Personally you shouldn’t be doing a model for a 3 story building in a FEA software. Keep it simple. If you still want to do it, use compression only springs to connect the beam to wall. That would be simple but I strongly suggest using advanced models for simple things.
I agree, such simple structure should not modeled and should be done using classical methods.
The reason i am trying to solve is my curiosity. otherwise I already designed and executed that structure 5 years back with simplified approach, and its still intact 😇.
unfortunately i did not found the answer for my question, and i considered it a good forum to discussed, thats why i raised the question.
Are not we are here for the same reason, Should not give up and try to find the answers which we can't find else were?
Muhammad
You can try links or compression only springs.
Incase you model the wall for gravity only loads the modelling in the FEA analysis will still show you the hogging moments under certain load cases as it will take that as a deflection. You can try another simple approach in which you model the equivalent concrete beam element for the masonry above your beam slab similar to equivalent steel or concrete n=Es/Ec, This will provide the additional depth to the beam/slab below which will reduce the hogging moments. The issue i always found with the links and springs is the definition of there properties and the force capacity as it is very difficult to determine for the plastered walls or block masonry.
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
