Job Guidance
M_R
Hi,
I am currently a final year MEng student at the University of Sheffield, and was hoping to get some advice about securing a graduate job in Pakistan. I am applying to various UK based companies, but considering the current UK economy, I want to have a backup option available at home (Karachi).
Can anyone provide any guidance as to where I should be looking for a job in Pakistan?
I would suggest that you network in UK and try to get in some company there instead of looking at Pakistan.
I know some friends who went abroad and were able to land something based on their networking skills. Your starting point is your University Alumni Network. Good luck.
 I will agree with above and suggest you try to look for something in the UK market as this will be hugely beneficial for you professionally and the experience will be immense. the projects and there nature is different in UK market and u will be surprised with the approach methods for each design problem. This will provide you a good base and will help. I am sure you will land a job soon but keep your focus there only.
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
