Concrete Slab Design
sochtheking
Hi guys I just joined the forum today,
I would love to get some of expertise on how to go about this issue. I'm in my senior year, and my senior project is to design anything of my choice. I picked to design a mansion using RCC structural system. I have just finished laying out the columns and beams and now have moved onto slab design, I am a little stuck on the hand calculations as this configuration differs from text book examples.
My main questions:
1. Some slab panels do not align on the same column lines as each other, which makes using the conventional EFM alittle more tricky. How should I tackle this problem? In the figure, you can see I highlighted the situation.
2. The layout has a mixed of two-way and one-way slabs, this means that I cannot use ACI tables to manually distribute the moments based on L1/L2. How would you guys suggest dealing with this?
All input is appreciated and welcomed.
Thank you guys ahead of time.
The purpose of structural analysis, as Graham Powel puts it esoterically and with simplicity, "is not to get an exact simulation of behavior ..... the goal is to get demand/capacity ratios that are accurate enough for decision making". The exact analysis is not required for engineering problems, and it is not possible as well.
For most RC slab-beam systems, the slab is only required to resist gravity loads. For gravity loads, you do not need to do ELF. The coefficients method of ACI 314R-11 will do the job even with its limitations. Same is true for one-way panels; you can use coefficients in ACI 318.
For academic purposes, you can model your floor system in SAFE or can get the results for ETABS as well, as it can do design of slab as well.
In actual practice, the level of investigation and scrutiny put on a particular structural member depends on the importance of the structural member in overall structural system.
In your case, RC floor is the structural member with most load paths. It can transfer loads in ways unimaginable by most structural engineers. It does not warrant a detailed scrutiny unless it is acting as s transfer member at podium levels of a tall building.
Thank you for the response. I understand the point you are making. Regarding the use of the ACI coefficient method, what if there is a case where is an intermediate column which is not situated in the corner of the panels, how do we take this into account when considering the case to pick. I attached an image for reference
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
