Design Procedure
Sameer Khan
Salam!
I'm a fresh Civil Engineer who is not much familiar with design/analysis of actual buildings. Someone please elaborate how the whole process of design of a building is carried out?. Another thing I want to ask is to please suggest some reading/watching material(book/notes/tutorials/udemy course etc. ) to get me familiar with the core concepts of structural Engineering is easiest way (not the Nilson,McCormic type of books). I, being met with worse structure subjects teachers in UNIVERSITY haven't been able to learn this beautiful subject to my full potential. Now I'm trying to self-learn things that I missed in uni. Any advice/suggestion would be much appreciated. Wassalam
Salam, if you didnt get from teachers, best to get from books, Nilson is one of them, hibbler for structural analysis and materials mechanics, one book of geotechnical basics Braja M Das or any other, after studying in depth you could get someone senior engineer who could mentor you, without studying there is no formula to teach yourself, mentor can not help mentee without this, more accurate mentor and mentee will waste each others time.
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
