Need a little Guidance of Software for Foundation Design
Jawwad Khalid
Dear Members,
I just came across this platform for Structural engineers of Pakistan , and delighted to see it.
I am working as Manager in a power utility company in Karachi, and sometimes required little structural designing,
Can anyone here recommend what software should i learn/use for designing these basic equipments' foundations?
Looking for valuable inputs from members here, thanks
salam, better you get services of some experienced design engineer near you who can design for you, learning software shall not be helpful, software is a tool, design requires knowledge, practice under-supervision, and more . Thank You
On 4/25/2022 at 1:14 AM, Jawwad Khalid said:
Dear Members,
Waqar has a valid point but since you are also an engineer, you can start with manual design (review course notes) and for foundation software, CSI SAFE is widely used in Pakistan for foundation design.
Edited by UmarMakhzumi
  • UmarMakhzumi changed the title to Need a little Guidance of Software for Foundation Design
Hello from Gensoft 👋
Gensoft is an online designing organisation, offering software services such as Web Design & Development. Basically we provide a better look to your websites with our technical support includes ERP Solutions, Enterprise, CRM Software, HRM Software, Finance Software & Cloud Accounting.
Our offshore solutions are aimed at designing software and websites across the globe. We consistently attempt to combine innovative technology with learning to meet the needs of our clients. In order to fix any potential issues, we highly prioritise staying in touch with our customers at every stage of a project.
Our highly skilled Designers are at your service 24/7. Feel free to reach out Gensoft, the most creative and reliable company to enjoy a fascination look of your website.
For more details kindly contact: www.gensoftgroup.com
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
