Concrete beam side clear cover in ETABS
Rifat
As salamu alikum,
What is the default value for the side clear cover for the concrete beam in ETABS?
Is the side clear cover value is same as the top cover or bottom cover? If I vary the top and bottom cover then which value is for the side clear cover?
If I want to maintain the top and bottom cover as 1.5 inches and 2.5-inch side cover, then how to adjust this in ETABS?
Thanks in advanced
Rifat,
I think you can define it in Frame Section Property Reinforcement Data. If your question is about cases where reinforcement is not defined, I don't have the answer on hand as I am out of ETABS for 10+ years now.
  On 5/9/2022 at 4:38 AM, UmarMakhzumi said:
Rifat,
Thank you Umar for your reply. In this box have a look "cover to longitudinal rebar group centroid" having two options top bars and bottom bars. How if I want to define clear cover from side face of beam (not from top and bottom) then how can I do in ETABS?
