ETABS Design Not showing any Steel for Beams and Slabs
Sharjeel_ghauri
I am new to Etabs, I successfully designed and analyzed a 3 story building. But I came across with very strange problem, when I tried to design a small room of 2m x 2m size on etabs. When I imported my etabs design results to CSI Details to check reinforcement, it is showing 0 rebars for slab and Beams, while an unrealisticly heavy reinforcement for a small 200 x 200mm column. I have attached the section for both Beam and Column. Although I used the same method, which I used when I was designing a 3 story building. Can someone please guide me where am I doing the mistake?
It can be due to a number of reasons. If your 3 storey building design was reasonable and this one is off,  you could have made a mistake in applying the loads (check units), defining material properties (again check units) or load combinations.
Check your reactions for basic load cases and manually do and compare controlling load combination reactions with ETABS. That would be the starting point.
Previously I chose the size of Beam to be 100 x 400mm , I tried to change the size to 200 x 400, and now it is showing steel details in CSI Details. But for slab (150mm) still the issue is same. With the issue of beam resolved it seems like there was no issue in the units or loads. But what should be the case with Slab still I am unable to apprehend.
It is hard to tell, especially when I don't have time to review your Model. All I can suggest is going through the Basic Loads check and re-checking your input. Also, is your copy of ETABS licensed or not? If it is not licensed, then the version you are using might be buggy.
