Constructability in construction process
Asif
Hi friends,
I hope you all are doing well. Recently I visited a site to check the reinforcement of a 2 story frame structure building. I found #8 dia bars being used in beams where i think #6 (with same Ast) could have been used. I met the steel fixer there and his comments can't be mentioned here. Dear folks, as a Structural Engineer our goal should be stability with economy but while designing we sometimes ignore the constructability aspect of the project specially in small scale local projects. As there is no skilled labor in  remote areas so we should also consider the site conditions in our design and we should make our design more simple which can be easily executed.
Edited by Asif
Salam Asif,
There are constructability issues true, but its not on structural engineer issues only. Sometimes residential designs are not even designed or checked by structural engineers, client/architect or rep get drawings from a draftsman, get stamped from a tout and process for submission/construction. Client hires architect/contractor for full project, they hire someone with lowest bid, who doesn't care about design/economy/constructability.
if its properly designed by structural engineer then it must not be so without requirement, all aspects shall be considered.
Thank You
6 hours ago, waqar saleem said:
Salam Asif,
Thank You
You are right waqar, but in my case the design was not only by a structural engineer, but also rechecked by a senior engineer. Thanks
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
