SMALL HOUSING INDUSTRY!!! Food for thought, beneficial research works.
Small housing industry is all time necessity , small dwellings are required to start a family unit, but its very unfortunate that houses are going costly day by day.
Private societies have been substitute for housing needs but now they are main cause of making them costly, developers/builders/propertieay are selling poorly developed lands on premium costs. A small plot is selling at 80 lac (8M), then in societies due to poor, non-engineered fills, there is huge cost of foundation stabilization, around 3M to 4M, after heavy foundation expenses there are chances that foundation might settle or deform, in some cases fills are more than 40ft, and consolidation takes too much time, water ingress is another issue. Foundation engineers need to come forward and tackle this problem, this is a practical problem and could benefit a lot of people, universities can develop a collaboration and can come up with some good solution in few years. Till now this problem is tackled by structural engineers (talking of my area, other areas might have better solutions already), and they are adding structural piles underneath foundations, piled raft, but problem is on geotechnical side so its geotechnical solution is required that should be affordable, structural solution is not affordable. Structurally lighter materials can assist to decrease stress on subsoils. On fills lights weight concrete or LGS or SCIP or modular houses shall be constructed. But for this people shall develop taste for new materials and alternatives.
A family constructs house from their hard earn money, this should not be that difficult and costly. Future development should be improved, though there are no chances, developers/propertieay just need money, they leave ethics aside.
People themselves shall ask for soil condition before buying plots, its not wise to buy a sick horse and then spend money on its health, i have observed propertieay (this is my term for property dealer) who jump on the filled areas and say see how hard is the land. Ethics? they dont bother. No Govt., society or anyone shall come to our help we shall stand for ourselves.
Thank You
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
