Introduction
Dik
I'm an old codger with over 50 years of good engineering experience. I'm still actively designing. Most of my work, now is related to structural steel connections, but my experience is very wide. The reason for joining this site, is that there is an engineer in Vietnam that has a very irregular building 'footprint' (shape) and is seeking advice for locating expansion (control) joints. The joints are not constrained by dimension, but are determined by the irregularity.
Dik
Dik
Welcome to the forum. You have an interesting background.
Sure, if you can provide details and plans then other people can provide some suggestions.
Thanks for the response... I do not have release to provide the plan.  The building consists of three or four smaller structures (still regular sized buildings) and the 'footprint' of the structure is extremely irregular. The smaller sized structures are of different heights (multi storey).  It is a hotel complex in Vietnam.  Construction is reinforced concrete slab with drop panels, and in my opinion, needs real construction joints.
The engineer that was looking into the design was intending on using expansion joints predicated on maximum distance recommended by ACI. In reality the building should have joints at the interface of the various buildings. He was looking at a couple of joints as opposed to maybe 8 or 10.  I was wondering if somenone had a reference to joints based on building envelope issues.
Again, thanks...
I don't know if this will post... the sketch is public domain... The red lines are joints that I've suggested. Due to the difference in elevation of the varioius components, there could be others.
The building is really irregular. I would suggest isolating different sections of building if it is possible considering building envelope and architectural plans. For concrete buildings, the normal rule of thumb that I have seen out of handbooks in 180 feet. You can also refer to ACI 224.3R to further details.
Hope that helps.
Thanks... the building is extremely irregular... I don't think you can travel  150' without 'hitting' an irregularity. I was trying to find a source for control joints based on the irregular building envelope.
pour strips can be effectively used to mitigate column and wall creep and shrinkage, restraint of creep and shrinkage in long floors or roof systems, creep caused by prestress forces and volume changes caused by variation in temperature. It works in irregular plans as well. Moreover at the moment you have one irregular shaped foot print, by providing expansion joints as marked in red on above posted plan, you'll be facing at least two irregular foot prints.
Pour strips work OK, but generally not when you have a transition in structures.  The plan is a compilation of several structures. You want a real joint at those junctures.
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
