UGWT Location within the Raft
Zohair
What is a UGWT?  UnderGround Water Tank?  Best to locate it as far from the foundations as possible and as close to the floor.  If you have frost issues, there are a couple of other issues.
what type of foundations do you have?
Edited by Dik
Added question.
Raft Foundation
How far below grade is it founded?  How thick is it?  Can the UGWT be built into the raft foundation. Can it be expanded in size to minimise the depth and the loads on the tank walls?
Salam Zohair, it ok to have water tank there, just check any column loads which are around the periphery of tank and design walls of the tank for shear, take care to make its foundation joints and other top slab level joints are sealed, any leakage could create serious problems.
If leakage is a serious problem then a waterproof membrane is nearly always prescribed. If a little leakage is OK, then you might consider a perimeter drainage system around the tank and sump pit .
Edited by Dik
correction
