Concrete Dampness !!!
can we make concrete completely damp-proof,as i have plans to make a lawn on the first floor top due to space shortage i m thinking to have it on the first floor is it feasible.????
Can be very expensive if you want to grow grass. you have to use gravel, embedded in geotextile with perforated pipes under the lawn you will be growing to provide drainage. Plus, no one knows, what loading is your terrace capable of unless got it designed when it was being built.
To reduce moisture migration through concrete floors, place an impermeable water barrier over the rock and gravel before placing the concrete. Polyethylene fi lm is low cost and easily installed, but it is easily punctured and difficult to seal at the edges. More durable products are polyethylene-coated Kraft paper and glass-reinforced waterproof paper, extrusion coated on both sides with polyethylene. Use 8 mil or heavier material and do not puncture the barrier.
