Tips For Managing Projects
Becoming a great project manager need so much learning. You need to juggle time, money, people, equipment and materials. To do it all, some people feel like they have to be a miracle worker! But it's not the case. Just take these essential tips...
Initiate Carefully
When you start your project, wind it up slowly. Define the process by which you're going to manage your project from start to finish. Adopt a Project Life Cycle so you know what you have to do and by when. Then take these steps:
1. Define the project goals, timeline and schedule
2. Quantify the amount of resource you need
3. Specify the project scope and deliverables
4. Decide if you need to outsource to a supplier
5. Recruit your team and set up a project office
Plan In Depth
Then identify all of the tasks needed to complete your project. Prioritize them and calculate how long each will take. Create a detailed project schedule, so you know what you have to do, when and how. Then take these steps:
6. Identify the number of resources you need
7. Set a budget and plan your expenditure
8. List the deliverables and set quality targets
9. Plan your communications so everyone is informed
10. Decide how you are going to manage risks, changes and issues
Execute Swiftly
The next step is to execute your plan quickly and efficiently. This is the longest phase in the project, so you need to work smart to complete this phase on time. Take these steps:
11. Record time spent by your team completing tasks
12. Frequently check your actual vs. planned progress
13. If you start falling behind, take action or get help
14. Resolve risks, issues and changes quickly
15. Keep your team motivated by rewarding good performance
Close and learn
When you've produced all of your deliverables and handed them over to your sponsor or customer, you're ready for closure. Do this by releasing project staff, contractors, suppliers and equipment. Then close your project office and handover documentation. Take the time to identify your lessons learned, as these will be invaluable to your next project.
To learn more please visit https://www.mpmm.com/
Practically most of times delay in issuance of deliverables is due to
1. Delay of input information.
2. Change in input information
Most of times point 15 mentioned by Muhammad Ali is overlooked.
Point 15 not overlooked but most of the people don't want to look over it.
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
