Here is a quick tutorial about how to create a new post in forums.
For the purpose of tutorial, lets say you want to start a new topic in "Seismic Design". See the attached images as they explain detail about posting.
Step 1: Click "Seismic Design" Forum from main index.
Step 2: Click on "Start New Topic" Button on top right corner.
Step 3: Fill out the required fields as explained in the attached image.
That is it! :)
Should you have any questions about posting, please ask below.
Many Thanks!
i am having problems in attaching files... kindly tell me how to attach a file in a post???
If you can't find the attachment button. here is how to do it
The other case is when you have problems "posting attachment", It can be due to the browser you are using. You will have problem if using Internet Explorer (The attachment is done using Adobe Flash v9, so make sure your flash is up to date) Anyways, best thing to do would be using Google Chrome, or trying the Basic Uploader. Please see the attached image.
  • 3 years later...
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
