Sap Modeling Issues
m_naeem_b
you cannot directly do this! to have both the grid systems you need to first put the cylinderical grid then import from cad the other grid system. I am not sure but you can try this way!
What i do when i have this type of issue is that i dont use cylinderical grids. rather i just draw the grid lines in CAD explode them so that they are not arcs or polylines just simple straight lines. If i require some curve. i dont break that arc cz i know SAP/ETABS will break them in 24 pieces of smaller segments straight lines.
Because I am beginner user of SAP as compared to ETABs and SAFE.
I want to model attached dome on SAP. But for inclined column, I have to draw grid lines. How i draw.
masjid dome plan.dwg
masjid dome elevation.dwg
Draw using this.
http://www.sepakistan.com/topic/3-etabssap2000-dome-geometry/
well no one can give you each and every detail about how to model it. We can provide you with the basic guidelines and concept, provided that you have the background in using the appropriate options and commands in software. I know we all start learning from zero but you need some one who can train you step by step; may be in your office. I have downloaded your files and if possible i can give you files 2 hrs on weekend to make a tutorial for you! happy? :P
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
