Sap Modeling Issues
m_naeem_b
you cannot directly do this! to have both the grid systems you need to first put the cylinderical grid then import from cad the other grid system. I am not sure but you can try this way!
What i do when i have this type of issue is that i dont use cylinderical grids. rather i just draw the grid lines in CAD explode them so that they are not arcs or polylines just simple straight lines. If i require some curve. i dont break that arc cz i know SAP/ETABS will break them in 24 pieces of smaller segments straight lines.
Because I am beginner user of SAP as compared to ETABs and SAFE.
I want to model attached dome on SAP. But for inclined column, I have to draw grid lines. How i draw.
masjid dome plan.dwg
masjid dome elevation.dwg
Draw using this.
http://www.sepakistan.com/topic/3-etabssap2000-dome-geometry/
well no one can give you each and every detail about how to model it. We can provide you with the basic guidelines and concept, provided that you have the background in using the appropriate options and commands in software. I know we all start learning from zero but you need some one who can train you step by step; may be in your office. I have downloaded your files and if possible i can give you files 2 hrs on weekend to make a tutorial for you! happy? :P
