Vulnerability Assessment!!!
it depends for which structure, up to what level and for which purpose you want to do the assessment of the structure. e.g, For masonry for RC frame for wooden etc.
Then there are several assessment methods and ways through which this can be done.
But in general for seismic assessment you have to select the building data in which you should have all the information of the building before and after an event. Then you design the building accordingly and do pushover, time history analysis or you can go for the capacity curve or even performance point of the building. Later you have to compare your results with the actual behavior of the building and you can assign any damage grade to the building. There are some damage grades defined in the European Microseismic scale (EMS 98).
This is general procedure but different details can be gathered and often there are difficulties for getting the data for a building before and after the event but then you have to go for different methodologies which many researchers have used.
thank you very much Nustian371!!!it is a nice explanation,i need to have the assessment of a RCC frame structure and thanx for uploading EMS-98 examples,plz send me the complete version at waqarraqaw@yahoo.co.uk
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
