Vulnerability Assessment!!!
it depends for which structure, up to what level and for which purpose you want to do the assessment of the structure. e.g, For masonry for RC frame for wooden etc.
Then there are several assessment methods and ways through which this can be done.
But in general for seismic assessment you have to select the building data in which you should have all the information of the building before and after an event. Then you design the building accordingly and do pushover, time history analysis or you can go for the capacity curve or even performance point of the building. Later you have to compare your results with the actual behavior of the building and you can assign any damage grade to the building. There are some damage grades defined in the European Microseismic scale (EMS 98).
This is general procedure but different details can be gathered and often there are difficulties for getting the data for a building before and after the event but then you have to go for different methodologies which many researchers have used.
thank you very much Nustian371!!!it is a nice explanation,i need to have the assessment of a RCC frame structure and thanx for uploading EMS-98 examples,plz send me the complete version at waqarraqaw@yahoo.co.uk
