Need Help For Ms Project
Engr Laique Zaman
Laique,
An 'easy topic' will be the one, which is related to the structural course you like most to study and learn. However, actual research you will have to carry out, may or may not be easy in that sense, as it will depend upon the 'research type' (as explained below) you select for your topic.
Research topics at MS level are of generally two types. The first requiring analytical research,  and the second involving experimental work, to be carried in a laboratory through physical testing of specimens.
First type of research could be very inexpensive in case, firstly it can be carried out using existing resources and secondly if the availability of relevant data could be made economically. However, selection of a topic for this kind of research and actually getting through this kind of research might not be easy.
Second type of i.e., experimental research is more common, as it is not only easier to carry out, but also easier to get through with your final exam as well. It may also be comparatively less expensive, if it mostly requires commonly used & locally available material and does not involve extensive use of advanced but costly research materials (like fiber reinforced polymers (FRP), commonly being used in structural rehabilitation & retrofitting related research now-a-days).
Laique,
First type of research could be very inexpensive in case/ firstly it can be carried out using existing resources and secondly if the availability of relevant data could be made economically. However, selection of a topic for this kind of research and actually getting through this kind of research might not be easy.
Thank you Sir, i am interested in experimental research, sir i have a topic please sir give me some ideas about it and how much it will be expensive, and the experimental test can be performed locally or not, the topic is "Experimental and analytical investigation of the structural performance of FRC (PPFRC)". Sir please give me idea that this easy topic or not...?
Laique,
Before you can find out estimated cost of your research work, you must have to go through the following steps:
1. Make a research proposal and discuss with the professor, who will be your research supervisor.
2. Your research proposal would essentially contain the following:
    - Title of your research topic
    -  Aim of research
    -  Research type & methodology (In your case, research type will be 'experimental study'.)
    -  Types and total  number of test specimens to be made.
    -  Which type of fibres will be used, and what will be the percentage of fibres used for each type of test specimens?
       etc. etc.
3.  Finalize your research proposal, as directed by your professor, and get it approved from the concerned department / university.
From the above information,  you may work out quantities of various materials required for your proposed research. Now, you may check the rates of supply of all the involved materials from their suppliers/vendors, and can easily determine approximate cost of your research project yourself.
