beam moment M3 (maximum and minimum)
AOA,
I have attached the beam moment and shear envelop summary for a concrete frame structure modelled on safe. Only a single load combination was defined for dead and live load cases: 1.2D+1.6L. However, the table shows two moments: max and min M3. (but only one value for shear and torsion?)  How were these two values calculated? Shouldnt there be a single unique moment and shear configuration for a single load combination?
thanks
Hi Samiullah,
I will try to answer your question but I don't have access to SAFE. So I might ask you some questions to get a better understanding of the problem.
How many locations along the beam does SAFE report the results?
AOA Umar Bhai,
Start , middle and end just like in the table. although  in graphical view, it can show the full BMD and if i move the cursor across the beam, it can display value of moment/ shear at almost any location.
Edited by Sami Ullah Khan Bangash
W.Salaam,
I think the number of locations might be as per meshing for CSI Safe. I might be wrong here but when I use RISA3D, it allows me to select number of locations along where length where I want results to be reported. Normally, I choose 100 locations along beam length.
Irrespective of that, the softwares report results along the length of the beam. The question is that how does SAFE define "end", "middle" and "start" regions? Like if you have 100 reporting points along a beam length, would 100/3 in the middle be reported as "middle", and other 2/3rd as "end" and "start". You will need to look up SAFE software manual for that.
Let me know if the above makes sense to you or not. I will be happy to answer any follow up questions.
Bulls EYE!! Umar bhai your line of reasoning was right on. lol. I tried to find stuff in safe analysis reference manual but no luck. but then found this( attached in the photo below).
Turns out the max and min are just end moments for each of the start, middle and end regions. I also confirmed this by moving the cursor over the bmd in those regions and comparing the values being displayed. They matched. What a relief.!!
Thanks a tonne. (Y)
