Pile Design
asadishaq
kindly reccomend me a book or software for pile designing...
i came through an indian book which has a chapter on pile design TREASURE OF RCC DESIGN by Sushil Khanna,check that might be helpful to you :-)
I havent seen any books that people use in design office. The firm I work for has the in-house tutorials that help new people start.
tutorials arranged by seniors are best but these can not be substitute for books, books have the authentic knowledge and one can make a reference to any comment and most of the knowledge seniors have comes from books, sometimes rule of thumbs used by engineers which facilitate the designing process and could be different on the experience and level of the engineer, these rules can't be justified books are required to justify them.these books might be codes !!!
  • 2 years later...
its a chapter from a book about pile design. Good read.
I want to know the name of book as in this chapter there are references which I have to verify/quote in my design calculations and I have checked the example of single pile capacity from Bowles- chapter 16 which is also very easy.
I am looking for this book and I havent found it yet , If you have this book upload it on mediafire please...:)
  • 4 weeks later...
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
